Next suspension mod
Old Feb 19, 2005 | 03:16 PM
doodad's Avatar
Next suspension mod
I just installed my new bilstein shocks and 1le springs. What a difference over the original 96 stockers. I hit it hard and still have a little wheel hop as I punch second. I have LCAs, PHR and strut tower brace. What can I do now to eliminate that last little bit of hop?
BTW this is 96Z28 with CAI, long tubes, catback, 1.6s, and a good tune.
Old Feb 19, 2005 | 03:49 PM
Kataklysm's Avatar
Re: Next suspension mod
Adjustable torque arm or sub frame connectors.
Old Feb 19, 2005 | 10:10 PM
teke184's Avatar
relocation brackets
Old Feb 20, 2005 | 07:56 AM
doodad's Avatar
relo brackets even though I am not lowered? I thought torque arm right off, but I am trying to understand why this is even happening. I am not sure, but this may have started with the LCAs. I suspect headers instead, but now I can't remember when it really started.
Old Feb 20, 2005 | 08:02 AM
teke184's Avatar
the brackets will still benefit you even though you are not lowered. although i thought the 1le springs dropped like 1/2" or something.
instead of the TA you could just put in a poly bushing on the mount. that firmed up my suspension alot, after i had LCA installed.
but i'd bet the brackets would help the most
Old Feb 20, 2005 | 08:17 AM
doodad's Avatar
Well they are cheap and easy enough to give it a shot. What do you know about TA to accomodate LTs and Y? I assume I only have a few choices.
Old Feb 20, 2005 | 11:47 AM
teke184's Avatar
all TAs should work fine with standard LTs and Ypipes. it's more of a hassle with true duals.
any of the TAs that mount in the same manner as the stock unit should work fine.
RUENUF
Mar 13, 2016 03:37 PM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
