Newbie Suspension Questions
I know this is gonna sound dumb, but I don't know much at all about suspension parts and what they do. I was wondering what all the parts actually do for the car. Could somebody please list the parts and what their funcions are. Sorry for the dumb question, but I couldn't find it in a search. Thanks
Re: Newbie Suspension Questions
I found this on another forum, so I just copy/pasted it.
1. Subframe Connectors - Absolutely necessary to keep your F Body from twisting and stretching. I have seen too many of these cars lose their door to fender gaps from having gone too long without subframe connectors. Subframe connectors will make the car handle better, you'll get fewer squeaks and the car will get better traction.
2. Torque Arm - BMR, Global West and Spohn all make torque arms that relocate the front mount off of the transmission by relocating the front mount back behind the transmission. The relocation of the front mount relieves the stress from the tailshaft of the transmission that the torque arm places on it, as a result of trying to contain the rear-end and it's rotational stresses. The stock torque arm is a stamped piece of sheetmetal that has broken apart for many people, and it sometimes takes out the driveshaft with it when it goes. By relocating the front mount of the torque arm behind the transmission, the geometry of the rear suspension becomes much better and really aids in hooking up the rear suspension. While replacing the torque arm, check the transmission mount, as the stock torque arm places a huge load on the mount, and the mount breaks quite often when using the factory torque arm. The adjustability of these aftermarket torque arms allows the user to adjust the pinion angle of the rear suspension which aids in finding traction.
For those of you who are dragstrip bound, I would also add a few additional items.
6. Lower control arms - The aftermarket lower control arms are much stronger, and will not flex like the factory lower control arms. It helps keep the rear axel planted to the ground when you accelerate hard off the line.
7. Lower control arm relocation brackets - Lower control arm relocation brackets are meant to be used when the car has been lowered, which alters the angle of the lower control arms. We have found that the relocation brackets also help in getting traction in non lowered cars. We use the weld on style that BMR offers.
8. Panhard bar - The factory pan hard bar is pretty flimsy and additional traction can be found by replacing the factory pan hard bar with a heavier duty aftermarket bar. The rear in these cars tends to sit closer to the right side, and by purchasing an adjustable pan hard bar, the rear-end can be centered in the body.
9. Strut Tower Brace - Eliminate flexing in the front end by adding an aftermarket strut tower brace. You will also notice that the car will handle better with a strut tower brace.
A "search" would have turned up this thread, right here on this forum.... no need to copy and paste
http://web.camaross.com/forums/showthread.php?t=394217
Magenta_Hearts
Mar 29, 2017 08:54 PM
Hurin
Dec 13, 2014 07:38 PM
