New Tie-Rods, Any Way of Preserving Alignment?
New inner and outer tie-rods to go in tomorrow and was hoping there were some tricks or ways to keep from needing another alignment. Someone will have a method right?
Don't thinking counting the threads will help because of being a different manufacturer.
Thanks.
Thanks.
Just curious....I've never done this but as a backup to measuring....if you used a set of ramps to get under the car, thus leaving the weight of the car on the wheels, popped the tie-rod without disturbing the steering position, and adjusted the new one to fit the knuckle, would that work in keeping the alignment?
It's done. The ramps might have worked but i can't see doing tie-rods without taking off the wheels.
Did one wheel at a time, matched up the old and new lengths perfectly, and installed without budging the spindles. STILL, the first test drive my steering wheel was 45* off, what the hell? after many adjustments in a big empty parking lot, i finally got the thing driving strait as an arrow and the steering wheel is dead center.
glad i swapped them, the old balljoints were toasted.
btw while i was under there i installed the twin air horns. will put pics + vid up soon, sounds like a ferrari horn.
If you are very fussy and precise, you can measure toe-in with a tape measure or string- don't have the procedure here at my finger tips, but it is one you can do at home without too much equipment-
IMO, take it to an alignment to get the toe set; that's a lot cheaper than buying new tires in a couple of weeks! Guess how I know!
The wheel is strait and the car drives strait, And i just put on a brand new set of Sumitomos up front, (thats why i replaced the tierods in the first place).
I believe you guys when you say the tow could still be off. but im not paying 60 bucks for some mechanic to turn my tierod threads 180 degrees when the process just seems so simple. Plus these shops around here so are damn busy you need to make an apointment a week ahead of time.
I might try this method when i have a chance.
http://www.extremehowto.com/xh/artic...ticle_id=60130
seems do-able right?
That actually sounds like a deal, it's at least $90 around here. Your right though, anyone can turn a tie-rod. But without the proper equipment or knowledge it's just a guess.
jasonduaine
Jun 4, 2015 09:29 AM
Hurin
Dec 13, 2014 07:38 PM
