New to Suspension, awful handling
Old Sep 20, 2004 | 12:49 PM
Z28WannaB's Avatar
My car handles like a boat, seriously it sways like I am riding in the ocean and the suspension creaks like an old rocking chair.
I was looking through AutoZone because I am pressed for cash, and I stumbled upon Shocks/Struts starting at 11.99 going to 89.99.
I bought my car used and as far as I know its got the original shocks on it. Would I see a significant difference in handling if I replaced them with the ones from Autozone?
Also is that ALL I need or are there some hidden parts I don't klnow about?
Thanks for your patience, I'm learning and this is the first car I've worked on and I love it! Though sometimes it can be frustrating.
- Z28WannaB
Old Sep 20, 2004 | 01:21 PM
87DJP2001's Avatar
Re: New to Suspension, awful handling
They might take the creak out of the rocking chair, and thats about it for cheap struts & shocks. I still have the original Bilstiens on my 87 IROC-Z and the car is as good as the day I picked it up from the dealer 17yrs ago. So that is a recommendation for Bilstiens.
Old Sep 20, 2004 | 01:26 PM
Z28WannaB's Avatar
I think I might throw on the cheap ones until I can get my window motor, paint job, and new tires then I'll consider upgrading.
I just need shocks and springs then? Excellent!
- Z28WannaB
Old Sep 20, 2004 | 05:09 PM
You realize that the front shocks can't be "thrown on"..... they require a fairly difficult removal from the front suspension in an assembly with the coil-over spring, and upper spring mount. The spring and shock then need to be seperated with a spring compressor. Generally, the top nut is rusted fast, and sometimes requires the top of the shock shaft to be cut off. Then the rubber covered top spring seat/mount is at an age where it may be rusting out, and might need replacement. A lot of potential for extra work and hidden costs.
I doubt you are going to find a coil-over spring for $11.99
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
tommalcolm
Sep 11, 2015 03:39 PM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
