New Pads N Rotors, Now Pedal pumps up n down while braking
So I just replaced all the rotors and pads on my car because I had some warped rotors. Now when I'm braking the brake pedal pumps up and down while i'm applying a constant pressure with my foot. The pedal acually moves my foot up and down while braking. Called around and Brake Depot said they think it might be a bad rotor. I already topped off the brake fluid. Any ideas on what this might be? Thanks in advance
you have a warped rotor. it is actually somewhat common for rotors to be warped out of the box. take the rotors in and have the turned. Be sure to clean off all of the surfaces where the rotors sit, clean out rust, road debris, etc. torque your wheels in the appropriate pattern at the right torque. After that, youll be fine.
Originally posted by Steve in Seattle
Probably just not bedded correctly.
http://www.stoptech.com/whitepapers/...otors_myth.htm
And I don't think turning brand new rotors is a wise move, you've just cut the service life of your rotor at least in half to begin with, and it doesn't address the fact that there may well have been a problem in the casting process that produced a warped rotor to begin with. If you are sure the problem is a warped rotor (a dial indicator will confirm this) then I would insist on it being replaced.
jj_burchiel
Mar 21, 2015 12:51 AM
Jul 4, 2005 05:00 PM
