New break set up
New break set up
I just took my 4th gen (2000) Z28 back out of storage. It's been lying dormant for around 2 years. Moved it a few times but that's all. I have a newfound appreciation for it and want to complete what I started. There is one thing I have no idea about yet and that is breaks calipers and rotors. From what I have read slotted rotors seem to be preferred over any drilled or variation of the two. I am curious to know what set up you guys are running and any info you might be able to give me to help me out with my decisions. I drive the car only half the year and when I do it's usually fairly casual. I'm not doing any street racing at least. I am looking for appearance as well so trying to avoid the rusting look. Paint or coating for that? Also painted calipers vs covers? Thank you for any input. I have done a little research but the answers are all over the place.
Re: New break set up
im by no means a brake expert, i bought cross drilled & slotted rotors thinking they would run cooler. now im told thats not true plus most shops wont turn those rotors so your one & done. they look good but i think thats it. one of my hawk ceramic pads is squeeking so im not sure how im going to fix that, not ready for complete brake job.
Forget the slotted & cross drilled rotors, they are just eyecandy. With the car being dormant for so long I would change brake fluid and also check the condition of the rubber brake lines (may want to go Stainless steel front & rear). Next rebuild the calipers install a good quality ceramic brake pads (Not aggressive type pads) and if needed turn the brake rotors (Or new ones if the thickness is below tolerance). Now all this will Break the bank account.
I just took my 4th gen (2000) Z28 back out of storage. It's been lying dormant for around 2 years. Moved it a few times but that's all. I have a new-found appreciation for it and want to complete what I started. There is one thing I have no idea about yet and that is breaks calipers and rotors. From what I have read slotted rotors seem to be preferred over any drilled or variation of the two. I am curious to know what set up you guys are running and any info you might be able to give me to help me out with my decisions. I drive the car only half the year and when I do it's usually fairly casual. I'm not doing any street racing at least. I am looking for appearance as well so trying to avoid the rusting look. Paint or coating for that? Also painted calipers vs covers? Thank you for any input. I have done a little research but the answers are all over the place.
From what I've researched on discs slotted is preferred over cross drilled and apparently has less fade in the rain (plus added cool factor), other then that normal rotors will be just fine.
If you have more $$ to spend or more track oriented goals you can do a more expensive aftermarket lighter weight systems.
I am considering this upgrade (LS1 brakes/spindles) myself right now too, the cost/performance for appears to be very good, and the bigger disks will look nice with the new wheels i have yet to get Wife approval on
. I'd recommend painting your calipers before swapping in new ones since it's nice and easy with them already off the car!
I think the LS brake swap is in a tie "for most bang for your buck" with higher ratio rear gears. One thing to add is the LS will work with the salad shooters, the C5 need a 17' wheel.
Yes, it is a fit. Downside is the C5 caliper piston volume is smaller, coupled with smaller LS1 rotors, increases the brake bias to the rear quite a bit. If you are going to mix and match parts, here is a good tool: Bias Calculator
Victor Lamb
Aug 26, 2017 02:52 PM
guionM
18
Jul 11, 2002 01:45 AM
