Need to replace Caliper
Old Jan 7, 2009 | 02:07 PM
cblinkdude182's Avatar
My driver's side rear brake is sticking after I did a brake pad and lube job on all the brakes. After driving just a little bit the wheel is really hot and an excessive amount of brake dust is on the wheel. I went back and made sure everything was lined up right and lubed up more, but still to no avail...
Also could this gap be the culprit, I noticed it on both sides but this side a little more exaggerated,
Any advice?
Old Jan 10, 2009 | 09:16 AM
onefastmx5's Avatar
It almost seems as if the parking brake mechanism is stuck. Make sure they cable isn't seized (push in and out by hand), and that pivot point moves freely. I have a problem with mine as well (threaded pin and retainer clip are wore out, so it just pops off when ebrake lever is pulled).
carguy0119
Apr 11, 2016 11:11 PM
Z-rated97
Mar 29, 2015 11:17 PM
Cam's maro
Jan 8, 2015 05:01 AM
FirebirdGT
Dec 13, 2014 10:25 PM
Hurin
Dec 13, 2014 07:38 PM
