Need to replace the bushing but can get them apart
Old Oct 13, 2007 | 11:11 PM
mrmint69's Avatar
I also have a 79z thats stock with 175K miles. The front contral arms bushing are shot if not gone like the top 2 rear. I can't get the control arm and the metal sleave to seperate from each other. I used a puller and can seperate the inside part but it looks like the outer part is rock solid. Is there a tool or technique to get 30 years of metal apart?
Old Oct 14, 2007 | 03:41 AM
v7guy's Avatar
I don't know about 30 years worth but I've had a lot of success with 10- 15 r old stuff when using PB blaster for days before disassembly and then some heat if necessary.
Old Oct 14, 2007 | 08:30 AM
jhthornley's Avatar
I've
drilled out the rubber middles before...
and then used a hack saw to notch the inside of the sleeve... (being careful not to cut the control arm itsef.).
Once you're thru the sleeve... even 3/4 of the way, it becomes weak and collapses somewhat which allowed me to pull it out.
Did this on rear LCA bushings... (not sure if front are similar??)
Old Oct 14, 2007 | 01:18 PM
mrmint69's Avatar
I sprayed the PB Blaster just before but never let it sit. It should be good and soaked in by now. I like the cutting idea a lot and maybe the heat method. Will give it a try. Thanks for the help guys!
Old Oct 14, 2007 | 02:16 PM
rexcellent's Avatar
If you have access to a hydraulic press go with that. See if any local shop has one where they can do it for you, they may charge a few dollars but it is well worth it. It will take you maybe 2 minutes to press out everything, definitely the easiest way to do it.
Old Nov 13, 2007 | 02:51 PM
mrmint69's Avatar
Hacksaw and hammer after drilling out centers did the trick. Thanks for the help.
Fatdog2
Apr 10, 2015 12:07 AM
blac94Z
29
Mar 25, 2015 04:21 PM
dbrockma
Feb 16, 2015 02:56 PM
Jason Short
Jan 19, 2015 06:34 PM
tspangle_95Z28
Aug 17, 2002 03:54 PM
