Need a little help.
Need a little help.
I have a few things done to my car but my suspension is old and completely stock(WS6). I want to upgrade my suspension to be able to get the power to the ground better. I was thinking about a nice NEW set of shocks (maybe bilstien) a set of LCA's.I am mainly focused on striaght line racing but would still like to handle decent. any suggestions would help.
Thanks ,Sean
Thanks ,Sean
Re: Need a little help.
This is always a tough question, its very hard to get the car to do both (handle and launch) well. Anyway you go in my opinion you compromise one for the other. I tried to do this with my Z when I first purchased it and what I ended up with was a car that did nothing well.
About 2 years ago I decided I wanted to quit getting my *** handed to me on the street so I went completely straight line performance with it, Eibach drag launch kit, no front sway bar, BMR adjustable TA, BMR relocation brackets, and the one questionable purchase, KYB AGX 8 way adjustable shocks.
Not that the shocks are bad but in hindsight I should have went with at least the QA1s.
Its been my finding though that tires are the great equalizer, a good set of sticky tires will do wonders for straight line performance.
With the suspension setup for straight line traction and the tires.....its pure gold.
If I wanted to try to do the handling and stoplight to stoplight again I would build for the corners and throw the MT drag radials on for the late nite stoplight drags.
Sorry this is so long but the suspension revamp I did made a world of difference so I just wanted to say that its best to decide what you want the car to do and then build for that, you will be much happier in the long run.
surreybrad
Sep 29, 2015 09:00 PM
