Need Help w\ popping noise
Old Apr 27, 2004 | 02:20 PM
GMRULZ's Avatar
I recently installed a BMR Kmember, and lower control arms.I also installed LS1 brake swap w\ new rotors and pads. Now whenever I slam on the brake in forward or reverse I get a popping noise like something was under a bind. I have tried all manner of fixes to no avail. the noise seems to be coming from under the shifter area in the center of the car.
Here`s what I`ve done:
checked every bolt in the front end and brakes all are at spec.
Was afraid my ls1 tranny mount might be broken, repaced w\ a poly, still have the noise. Although it was difficult to line up the trans crossmember w\ the mount had to pry the tranny to the driver side by a 1/4 of an inch to line up and get the bolt in.
checked the torque arm to verify that nothing was loose, everything tight , no cracks ect..
Any help would be greatly appreciated.
I have a 96 LT1 TA a4
Old Apr 27, 2004 | 03:14 PM
Stoopalini's Avatar
What ft/lbs did you torque the LCA bolts to?
Thomas.
Old Apr 27, 2004 | 03:19 PM
GMRULZ's Avatar
72ftlbs
Old Apr 30, 2004 | 02:53 PM
GMRULZ's Avatar
you mean to tell me nobody`s had any noises after installing a BMR Kmember. Thats hard to believe. Come on guys how bout some help?
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
autoxr166
Sep 25, 2015 04:21 PM
Toxintwins
Sep 11, 2015 11:13 AM
