need help removing front shock (left)
Old Aug 1, 2010 | 07:17 AM
smkeeling's Avatar
With removal of the brake booster, how or what do you use to keep the lines plugged to the ABS modulator. To drain the brake fluid, remove two lines and two bolts to get starts seems pretty easy, but I haven't found anything to use to plug the two lines so no air get to the ABS system.
98 Z28 converted to SS Loud mouth exhaust
Old Aug 1, 2010 | 08:24 AM
If you are just removing the shock, you don't need to open any brake lines. Just unbolt the master cylinder and gently move it out of the way of the bolts.
Old Aug 1, 2010 | 09:06 AM
Once you open up the lines, you have air in the system.... too late now.
Step #2 of my online front spring/shock replacement procedure:
2. Remove the two nuts that hold the brake master cylinder to the power booster unit. Do NOT disconnect any brake lines. Pull the cylinder away from the studs so it can be pushed gently toward the passenger side when you remove the two Torx head bolts for the upper spring seat.
Maybe the setup is slightly different on the 98-02 cars??????
Old Aug 1, 2010 | 09:17 AM
smkeeling's Avatar
Wheres the link to your HOW TOO on shock replacement, being whats written in the Haynes manual must not be accurate. I am looking at replacing all the bushings and upgrading (in time) most of the suspension components.
Old Aug 1, 2010 | 05:23 PM
Originally Posted by smkeeling
... being whats written in the Haynes manual must not be accurate. ...
LOL, that's an understatement.
Click the first link in Fred's sig for access to his tech articles.
Old Aug 1, 2010 | 08:42 PM
http://www.injuneer.com/HALEibch.html
Old Aug 5, 2010 | 10:53 PM
bluz28's Avatar
FYI, also loosen the two nuts/bolts that support the ABS block to minimize bending the brake lines.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
