Need help with brake problem!
Old Dec 12, 2007 | 09:27 AM
Huntr1117's Avatar
Question Need help with brake problem!
I've searched the threads and I can't seem to find anything, but here's my prob. My brakes have started to act really weird. It doesn't always happen, but when I press on the brakes the rear brakes seem to squeel very loud and don't seem to catch. It's almost like they seem to bounce like they catch for a second and then let go again repeatedly until it stops. A very jumpy stop and the brake pedal seems to let go until you stop or slam your foot down on it. So I replaced the rear pads and rotors and I have plenty of brake fluid. It's only the rear brakes that do this. Anyone have an idea of whats going on?
Old Dec 12, 2007 | 05:53 PM
Wrong forum. Moving to "Suspension...... & Brakes".......
Old Dec 12, 2007 | 07:27 PM
Greed4Speed's Avatar
It isn't a matter of having plenty of fluid, you need to have FRESH fluid.
Brake fluid is hydrophilic. It attracts moisture and then it'll start to boil when hot and you lose pedal pressure.
Changing fluid will help with your pedal feel.
Lets start with the simple stuff for the grabbing/pulsing problem. Your rotors are most likely warped. Get them turned.
Old Dec 12, 2007 | 08:36 PM
Huntr1117's Avatar
I just replaced the rotors and pads with new ones and it didn't help. If it was a problem with the fluid wouldn't it do it all the time?
Old Dec 12, 2007 | 09:52 PM
I missed the rotor part. So that rules out the most basic. Do you have ABS?
The fluid will help with pedal feel. It wont solve the problem, but it is part brake maintenance.
Old Dec 12, 2007 | 11:20 PM
Huntr1117's Avatar
Yes I do have ABS and TCS but I'm pretty sure that the TCS has nothing to do with this. What can I troubleshoot with my ABS to try and narrow down the problem?
Old Dec 13, 2007 | 09:42 AM
I've had some odd problems from the junk getting in between the sensor and reluctor ring.
Old Dec 13, 2007 | 09:45 AM
cause4panic's Avatar
sticky caliper is my guess, and possibly air in the lines
Old Dec 15, 2007 | 01:10 AM
RE AND CHERYL's Avatar
I'm guessing ABS related. As a troubleshooting step pull the ABS fuse and unplug the solinoids on top of the ABS valvebody. This will effectively shut down the ABS system. If it still happens after this it is related to the basic brake system and probably not the ABS.
Re'
Old Dec 15, 2007 | 12:24 PM
Huntr1117's Avatar
Re'
This is the type of suggestion I was looking for, thanks. The ABS valvebody is to the left of the fuse box on the drivers side right? If I unplug the solinoids it will be ok to drive just to try it out right?
Old Dec 16, 2007 | 05:17 PM
Huntr1117's Avatar
Alright so I pulled the fuse and unpluged the solinoids on top of the abs valve body and the problem has seemed to go away. So now what?
Old Dec 17, 2007 | 06:51 PM
Huntr1117's Avatar
Anyone?
Old Dec 18, 2007 | 09:58 PM
TobyZ28's Avatar
Clean your wheelspeed sensors on the rear ABS is kicking in prematurely...
Old Dec 18, 2007 | 11:40 PM
Huntr1117's Avatar
What do I clean them with? Wipe them off? Aren't they magnetic?
Old Dec 21, 2007 | 12:57 PM
dhdolphns's Avatar
I had a major brake problem that ended up being fixed by cleaning my rear wheel sensors..
I had my ABOS INOP light on, Low traction Light On and My ASR light on every time i first used my brakes...cleaned my rear wheel sensors and all is fine now
