need help with brake job.
I'm changing my brake pads right now and for some reason I just can't push the pistons back so it would fit over new pads. Acctualy i can't push them back at all. one side goes in easy the other does not move at all - could it be stuck or something? Is there any trick to it?
Any input welcome. Thanks.
the cap is off and I was using 4'' c clamp and it did not work so i unscrewed the oil line and got the whole thing out trying to push it in with the wise and it still don't want to move. I dont know.
Were your pads worn mainly on the end that has the stuck piston? That would confirm the piston is seized in the bore and wasn't retracting, wearing out the pads. If you can't push it in with a vise, its frozen and needs to be rebuilt or replaced.
RUENUF
Mar 13, 2016 03:37 PM
