Need a good affordable brake setup
I need a good affordable brake setup to put on my car, right now it has stock V6 Brakes and the car run a 12.1 with street tires. recently i became very ill and cannot work for a while, I too kthe car apart a few weeks ago then this came up and i dont have as much money as i was planning on spending. I know these brakes are not cutting it for the speed of the car, now with the tubular front end i just put in its gonna be even a tad faster. I was gonna spring for one of the $1500+ plus front brake kits from baer or wilwood but now i dont know what im gonna do , i kinda need something under 500 bucks if someone can give me some suggestions. this has been a hard *** winter.
Convert it to an LS1 set-up. The fronts are dual piston calipers with a 1 inch larger diameter rotor and Ive heard it makes a nice difference. Ive seen people on here that did a complete front swap with pads and rotors for under 200. Im gathering parts to do mine now (front and rear) and have a bit more than that in it but you could definitely do the fronts (80% of your braking power) with good rotors and pads for under 500 easily.
I don't know about the GTO setups, I haven't heard of anyone trying that. I agree with the above post for the LS1 upgrade. That is the best bang for the buck brake setup you can do. I picked up the complete front brake assemblies that even had new pads and rotors put on for 150 bucks from another board member.
You'll need the spindles as well. The LT1 hubs will interchange. Here is a good link as well for the install: http://www.fbody.com/tech/details.cgi?id=30
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
