my frist try at brakes with abs delete
like title says here are some pics of my home made abs delete lie lock soon to come and the rear line is not all the way done
if you hav any input plz tell
put the nut on the line before you flare that line for the rear brakes
but no really man it looks good, im in the middle of doing it and i wish i would've built it myself instead of getting the SJM kit.
thanks it was nice to make it myself and save the $ but it was a little hard with all the diff fittings
oh and i almost did forget the rear brake line nut
When I did the SJM kit on my car I had to actually bleed the fronts first and then move to the rear, I did it reverse of what you are supposed to and then did it again the right way (starting at P. Rear).
The second time on the same car I did it the 'right' way after the whole system had been open for a year or more and it all worked....car stops good now!
hey guys, i'm searching trying to solve a braking problem. I also have the SJM abs delete with the proportioning valve and the linelock. I've replaced the master cylinder, bench bled it correctly, bled the brakes several times, no bubbles left yet my pedal is still spongy. Am i missing something obvious here either with the line lock or the proportioning valve? my brother and i have bled that car at least three times now, i'm really surprised it still this spongy. I have to pump it twice before i feel pressure to actually stop the car.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
