lt1 ball joints
Old Mar 1, 2005 | 10:10 PM
blackztpi's Avatar
lt1 ball joints
are the lt1 joints hard to swap? not figuring they are much different fropm the conventional setup. are they rivetted in like most stock units? thanx
Old Mar 2, 2005 | 09:59 AM
OBE1 95Z28's Avatar
Re: lt1 ball joints
Upper ball joint is riveted in place, the replacement ball joint will come with bolts and nuts to replace. The lower ball joint is pressed in place. You can remove the lower arm and take it to a shop to have it pressed out and the new one in. I believe some of the auto stores will lone you a tool to press out/in yourself; I've read several posts that this can be an adventure.
Old Mar 2, 2005 | 10:14 AM
Flip94ta's Avatar
Re: lt1 ball joints
I just installed BMR LCA's this weekend and it is a PITA to mess with stock ball joints, We used the pickle fork at a 45* angle and a sledge to break the joint free and then we installed the BMR's which thankfully come with the joints allready pressed in.
Old Mar 2, 2005 | 10:16 AM
Flip94ta's Avatar
Re: lt1 ball joints
Oh yeah that 45* angle was down, as in pushing down on the A arm.
Old Mar 3, 2005 | 12:18 AM
OBE1 95Z28's Avatar
Re: lt1 ball joints
Harbor Freight sells a "press" to separate ball joints; there's 2 sizes and there about $8 each. Piece of cake and doesn't destroy the seals if you're going to replace the ball joints.
Old Mar 4, 2005 | 09:20 PM
NOSCaMaRo's Avatar
Re: lt1 ball joints
If you go with new ball joints, go with Moog. High quality lifetime warranty part
Old Mar 4, 2005 | 11:14 PM
blackztpi's Avatar
Re: lt1 ball joints
ok, I've never delt with lt1 ball joints, but i've delt with many others from shop experience. think I'll be ok with average garage tools plus a fork? thanx
Roadie
Feb 16, 2015 10:34 AM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
ModdedNerd
Dec 10, 2014 08:42 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
91 Redd Sledd
Aug 4, 2002 10:47 PM
