Ls1 and Lt1 lowering spring differences
Old Dec 20, 2005 | 08:53 AM
ddj19852003's Avatar
Im thinking of buying some intrax springs, they are for the 98-02 cars will these work on my lowly Lt1 or are these springs soley for the ls1 cars?
Old Dec 20, 2005 | 02:39 PM
Camaro_Maniac63's Avatar
Re: Ls1 and Lt1 lowering spring differences
The spring rates are probably different for LS1 cars compared to LT1 ones. You should call them and ask them, that is what they are there for. Good luck.
Old Dec 20, 2005 | 11:42 PM
convertz's Avatar
The front end weight of an LS1 car is less because of the all aluminum motor so the springs can be lighter I would think. I believe they all fit though because BMR springs are advertised as fitting 93-2002 for one set of springs.
just my thoughts tho
Old Dec 21, 2005 | 09:33 AM
Not "lighter", but "less stiff". Springs are mainly characterized via their stiffness; the equation is F=-kx, where "k" is the spring rate expressed in force/length. Anyways, enough physics
Old Dec 22, 2005 | 06:20 PM
convertz's Avatar
Thats what I meant. The stuffness of the whole system is characterised as
F=kx+cx(dot)+mx(double dot)
With m the mass of the system and c the damping coefficient
Im a 3/4 mechanical engineering student
Old Dec 24, 2005 | 02:08 PM
Just messing with you boss I am engineer myself and sometimes when someone posts something that may be misleading, I feel the need to correct it I later looked at your sig and realized you probably knew better than your initial post
Noenav
Mar 1, 2019 07:38 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
PaulN64
Aug 8, 2002 05:39 AM
