LS1 front brake upgrade questions
Old May 17, 2012 | 12:00 PM
undecidedfbody's Avatar
i am upgrading to a ls1 front brake setup and was wondering if there is any special brake line/hoses i need
it is out of a 98 and going in a 95
i have since deleted my abs/asr
i have spindles hubs brackets just need to know if i need special lines
thanks phil
Old May 19, 2012 | 07:05 AM
pgerst's Avatar
Re: LS1 front brake upgrade questions
The orientation of the hard line and the bracket that secures the flex/hard line to the frame are different between the LT and LS. As i recall, the end result is the LT lines are too long and the LS are too short. Think most people buy the lines for the vette; maybe they are in between? I bought LS brackets at the junk yard, and bent, cut and re-flared the brake lines so I could use the LS lines.
Old May 19, 2012 | 10:04 PM
ok so i would have to order 98+ braided lines?
bend new lines from line loc?bpv?
Old May 20, 2012 | 11:19 AM
pgerst's Avatar
Yes, I used 98+ lines, sounds like you may have had trac control so there is a different set for that as you get an extra rear line with trac control. I reused the old hard lines, cut them down a bit and bent them, as well as need to reflare them. Again, the LS has a different bracket as well from the LT that you will need to get at a junkyard. Here is a picture of the LS line and bracket: http://www.flickr.com/photos/72745513@N02/72334
Old May 20, 2012 | 06:23 PM
i will take it off the k member i got. i deleted traction control and put one line to back of car instead of 2. thanks for the help
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
vals95z
Mar 18, 2003 03:45 PM
slocody
Feb 10, 2003 01:04 PM
