LS1 Brake upgrade check list
Old Nov 25, 2004 | 06:40 PM
Red96Lt1's Avatar
Qustion1:
Just making sure. Is there anything that I have forgotten.
Parts needed:
1. LS1 kit (everything from the spindle out) -Ebay
2. Stainless/Teflon Brake lines -Thunder Racing
3. Dupli Color Paint, black & red & primer. -Lowes
4. Caliper Decals -Brent
5. Brake fluid -Autozone
6. Brake pads, front & rear -??
1. $220
2. $120
3. $25
4. $10
5. $15
6. $80, $60
Total $530
Qustion2:
Any suggestions on pads? I want relatively low dusting, rotor friendly, but better performance than stock. I guess this is what everyone wants in a pad, but I don't want squealing. I've heard wagner thermoquiet are pretty good, and have heard a little about hawk. Thanks!
Old Nov 26, 2004 | 12:05 AM
Z95m6's Avatar
Re: LS1 Brake upgrade check list
It looks like you have everything. Make sure you have a Tubing/flare nut wrench to take the metal brake line loose. I believe its 12mm if i remember right. A regular 12mm wrench will probably round the brake lines loose. I would also clear coat the calipers after you get the CAMARO decals on to make sure they don't come off. I did this on my LT1 setup and they lasted 2yrs until i took the calipers off. As for the brake pads i just reused the stockers that came with my setup. They were almost new, and even being stock my car still stops 10x's better than the LT1 setup.
Old Nov 26, 2004 | 10:19 AM
Red96Lt1's Avatar
Awesome, thanks! Almost forgot the clear coat.
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
danielbmx
Aug 27, 2002 11:11 PM
newby
10
Jul 27, 2002 11:39 AM
