Lowering Springs and Install Cost
Old Sep 21, 2005 | 11:03 PM
EviLBoX's Avatar
I just purchased some 17" wheels so now I'm looking to lower my car. I have long tubes and already have an issue with scraping, what set of springs would lower me 1" or less? I'm thinking of adding a set of Bilstein shocks from SLP as well. How much does a typical spring/shock install cost?
Old Sep 21, 2005 | 11:07 PM
Z95m6's Avatar
Re: Lowering Springs and Install Cost
BMR springs are rated at 1" i've heard they tend to drop a little more than that. I think Hotchkis has some 3/4" springs. My buddy has LTs and he just cut his factory springs until he got the ride height he wanted.
Old Sep 22, 2005 | 11:08 AM
Greed4Speed's Avatar
DIY and it'll cost you nothing.
Old Sep 22, 2005 | 10:18 PM
Bud M's Avatar
SLP has springs made to match those shocks. Don't know about the drop, though. Hotchkis have less drop than most.
The rear shock/spring swap is pretty easy, the front is a bit more work and requires a spring compressor and in all likelyhood an impact wrench since the top nut tends to rust up pretty good. I'd recommend having the front springs and shocks assembled by a shop. Also an alignment is a good idea after a spring install.
Injuneer has a nice write up on how to change springs and shocks on his website.
Old Sep 24, 2005 | 12:49 AM
Severous01's Avatar
if you have issues now with lt's, i wouldnt do it at all. i have mids and i dont scrape (i scrape at the subframes instead of exhaust) much. but if you want to lower it, i'd go with a custom setup. talk to sam strano at stranoparts.com and he'll help you out.
Noenav
Mar 1, 2019 07:38 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
PaulN64
Aug 8, 2002 05:39 AM
