Lowered car/adjustable panhard question???
Old Apr 23, 2005 | 09:56 PM
BadgeZ28's Avatar
I put proline springs and a adjustable panhard on my 01 Z. I needed to move things toward the passenger side to center up the rear end. The driver side emergency brake cable is stretched tight and I am wondering if it needs to be changed with these mods?
Old Apr 24, 2005 | 02:36 PM
Z28Nut's Avatar
Re: Lowered car/adjustable panhard question???
Is the cable tight with the car on it's wheels or just while jacked up with the axle hanging at full droop? If it's just with the axle hanging, I wouldn't worry about it, just be carefull when jacking the car in the future the cable doesn't get damaged. Go ahead and center the rear.
Old Apr 24, 2005 | 02:42 PM
GCEZ28's Avatar
You can release the tension on the cable at the pull handle. You need to remove the console. The E-Brake is a ratchet mechanism and it can be loosened. But I really don't think this is gonna be an issue.
Old Apr 24, 2005 | 02:48 PM
BadgeZ28's Avatar
Thanks for the suggestions. I had the car's rear wheels sitting on blocks and the cable just seems to tight. Its routing also puts it close to the rear end mounting bracket for the panhard bar and I am guessing it hits when the springs compress on a bump.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HectorM52
Jan 31, 2015 07:29 PM
thenewkid
Nov 27, 2014 09:41 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
