Lower Control Arm Relocation Brackets?
Old Feb 20, 2007 | 09:21 PM
Meatyshells's Avatar
i ordred some lca relocating brackets and i am scetchy as far as to where they go. But i think i have an okay idea after doing some research. But to make sure i took some pictures
and the lca relocating brackets go here?
Old Feb 20, 2007 | 10:07 PM
Bayer-Z28's Avatar
THose are the LCA's you circled. However, unless you are lowered, they won't help to to much.
Get some LCA's first, they help a lot. Good first susp upgrade. The LCA RLB's bolt in place of the rear LCA mounting point. You will have to bent the inside of the Ebrake bracket out of the way. Also, some bolt onto the lower shock mount. They go in place of the rear most bracket you circled in the 2nd pic. Bottom hole for lowered cars. Top hole on non lowered cars. They move the rear mounting point down twords the ground to keep the LCA's parallel w/ the ground.
I should have pics on my Cardomain page under my suspension upgrade...
http://www.cardomain.com/ride/463707/2
Old Feb 20, 2007 | 10:49 PM
ok thanks and my car is lowered, would it be a bad idea to install the relocating brackets with out installing new LCA's? or is that something i can do later when i get some more money
Old Feb 21, 2007 | 12:27 AM
It would be ok to install the brackets without new LCAs.
Old Feb 21, 2007 | 09:20 AM
teke184's Avatar
picture of my BMR bolt on brackets...
Old Feb 21, 2007 | 11:26 AM
Bud M's Avatar
BMR has nice pictures on their site that will make it clear for you
bmrfabrication.com
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
sseeya
Apr 9, 2015 06:38 AM
thenewkid
Nov 27, 2014 09:41 AM
