Left-Hand Tap
Old Nov 16, 2006 | 01:47 PM
ulakovic22's Avatar
Left-Hand Tap
Hey guys, I need help finding a 1/2" NPT "Left Hand" Tap. I'm trying to create a "turnbuckle" to connect my inner and outer tie rods on my manual steering rack (Pinto 71-73). I could use a conventional RH Tap, but that means when adjusting the toe I would need to disconnect it from the spindle.
Also is it a good idea to use jamb nuts on either side to keep it locked in position or is there something else that I should think about doing?
Thanks!
Old Nov 16, 2006 | 03:46 PM
mdacton's Avatar
s&w race cars has the tap its not pipe thread tho....you don't want npt
Old Nov 16, 2006 | 03:53 PM
ulakovic22's Avatar
Why not? Aren't NPT, UNC, etc. all the same? The original instructions say to weld one end to the rack and then cut the treaded end to fit and if need be re-tap with 1/2" NPT Right Hand Tap. I just cut a small piece off and then was going to use a Left Hand Tap in the other end instead of welding so I can adjust it without disconnecting it.
Old Nov 17, 2006 | 01:24 PM
ulakovic22's Avatar
Ttt
Old Nov 18, 2006 | 07:44 AM
mdacton's Avatar
npt pipe thread get tighter as you tighten it to seal the pipe connection, thats not what you need.....call a local machine shop or fab shop they have one and will probly thread it for you for free
Old Nov 18, 2006 | 09:43 AM
hotpart's Avatar
Former Vendor
Pipe taps won't help you and are sized differently than a regular tap. If you need taps I would suggest mscdirect.com. This is where we get most of our machining supplies for the shop.
Old Nov 19, 2006 | 08:28 PM
convertz's Avatar
msc is good or www.mcmaster.com
surreybrad
Sep 29, 2015 09:00 PM
FryedClutch
Sep 1, 2015 08:24 AM
95z_28_camaro_4_Ivan
May 10, 2015 09:28 AM
BigWil
Mar 29, 2015 12:24 PM
