LCA's and relocation brackets
I bough them with my lower control arms. i figured they couldnt hurt, and what do ya know, my wheel hop is completely eliminated. Now if i could just stop spinning maybe i would go somewhere. My tires are **** these days
I'd like to see at least a half dozen different cars with 6 runs each, 3 with stock brackets and 3 withJUST the relocation brackets to be able to say with some confidence that the brackets do work. I was contemplating getting some because everyone seems to think they work. but I'm building a Stock Eliminator type car so i checked with quite a few Stock Eliminator guys and the majority of them say they don't work.
You bolt them on using the stock holes for positioning to weld them on. If you don't use the stock location then you need to put in the spacer to prevent the bracket from buckeling when you put the bolt in. If you put the arm in the stock location you just wont use the spacer they provide. Just don't lose it if you decide to go to a lower mounting hole.
As for "does it work". It's plain physics. If it doesn't work then the laws of physics don't work and the whole world is coming to an end so who really cares about 60' times. If you have more power being directed to the ground and you don't improve your 60' time then it's something else in your setup that is causing a problem. As for cornering and handling, LCA relocation doesn't affect this at all. It's not moving your axle anyway, it maintains the stock position and the stock geometry through it's entire range of motion. If it feels like it's affecting your cornering then it's probably just the added traction and less lift you are feeling.
I'm not trying to bash anyone, just stating the facts. Just in this case, the facts are in the physics and not what someone says works or doesn't work. Arguing the point doesn't say that anyone here is wrong, it's saying that Mr. Isaac Newton is wrong.
Nayr
Mar 3, 2023 08:34 PM
