Koni singles or doubles
Old Apr 20, 2007 | 08:05 AM
ralf's Avatar
I have Eibach Pro-kit springs (so car is lowered down to the limits) and Bilstein HD shocks but as car is used for roadracing occasionally seems that Bilsteins are not up to the task on the track but stiff enough for the daily driving. I am looking at Koni adjustable singles or doubles but not too sure which one would be the best for my application - your input would be highly appreciated.
Old Apr 20, 2007 | 09:50 PM
Greed4Speed's Avatar
Single
Old Apr 21, 2007 | 05:21 AM
always faster's Avatar
^^^^^^^^^Like he said.
95% of owners dont need the DA
Old Apr 22, 2007 | 05:52 PM
Z28luvr's Avatar
what is the difference between the two?
Old Apr 22, 2007 | 07:03 PM
Moshbmx1's Avatar
Doubles adjust dampening as well i belive
Old Apr 23, 2007 | 04:10 AM
ralf's Avatar
that is the point - I need car to be reasonably soft at street and stiff on the race and do not need to lower it more - will singles do it?
Old Apr 23, 2007 | 07:56 AM
Your springs are what'll make it stiff. The shocks just dampen the spring's motion.
Eibachs are known to sag in the rear and ride the bumpstop. NO shock will help that.
Old Apr 23, 2007 | 11:43 AM
Bud M's Avatar
Singles are adjustable for rebound only, doubles adjust compression and rebound.
Old Apr 26, 2007 | 05:01 AM
ralf's Avatar
Does that mean in simple terms that ride stifness is adjustable as well in comparison with singles? I am lost
Old Apr 26, 2007 | 12:09 PM
Bud M's Avatar
Understand that when you talk about "stiffness" it involves spring rate as well as shock absorber compression dampening characteristics. Doubles do let you adjust compression dampening but to really change stiffness I think you would need preload adjusters on the springs.
You might want to talk to Sam Strano at stranoparts.com
Old May 15, 2007 | 08:52 AM
ralf's Avatar
Okay, after talking to Sam Strano singles it is. The only question is - will there be any noticable difference in comparison with Bilsteins? Anyone has any experience in comparing those two for roadracing/daily driving?
Old May 16, 2007 | 07:31 PM
Carlos01SS's Avatar
I've never roadraced but the Koni's are by FAR a much better shock than the Bilstein HD's.
Steering response will be quicker, less understeer that's for sure...
Your vehicle will feel better, more comfy ride, and yet you'll be able to drive her into the corners deeper than before.
It's a night and day difference...
I'm SURE you'll be quite pleased.
RX Speed Works
Oct 1, 2015 10:19 PM
cmsmith
Sep 14, 2015 09:25 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Bxlt1
Sep 10, 2015 08:16 AM
JJOHNROE
Sep 8, 2015 05:39 PM
