Kenny brown subframe connectors & true duals
Old Dec 16, 2005 | 09:12 PM
JoeliusZ28's Avatar
Can it be done?
First of all ill clarify what i plan to do. I plan to have two exhaust setups since i dont think i will be happy with one. I want to keep the single three inch for emissions and daily driving, but ill have a custom y-pipe that will flange at the collectors and right before the cutout so its entirely out of the way. For 'race use only' i want to have a set of 3" duals with an x-pipe and bullets that dump somewhere before the axle.
My question is, can they fit? i yet to come across any pictures of a car with KBDDs and true duals. my primary concern is that connector in the middle - drive shaft safety or whatever it is. First, is that thing necessary its never been under any stress when i unbolt it. if it is, i guess i could weld up a custom one to run the pipes over... or are there any aftermarket pieces?
thanks in advance
Old Dec 16, 2005 | 09:58 PM
revtime's Avatar
Re: Kenny brown subframe connectors & true duals
This will give you an idea of how much room you DON,T have to run true duals. I installed a Granatelli Gload brace where that wavy metal was, those are puple horny header mufflers with turndowns that I had cut down to fit and had O2 bungs welded in.
Old Dec 16, 2005 | 10:01 PM
JoeliusZ28's Avatar
thanks for the pic, i would run the duals down the side like that if i could, but with the subframes I HAVE to run them down the middle, is it possible at all?
Old Dec 16, 2005 | 10:04 PM
revtime's Avatar
Anythings possible, depends on what you can live with.
You could delete the the crossbrace (wavy metal) and run both tubes down the tunnel I suppose but it will be tight.
Old Dec 16, 2005 | 10:12 PM
JoeliusZ28's Avatar
well i would only be running this exhaust temporarily, so would i be fine without any brace in the middle? at the track too? (is that against safety regulation?)
Old Dec 16, 2005 | 10:21 PM
revtime's Avatar
Its not a driveshaft safety loop. Removing it will not hurt anything as far as straight line acceleration. Alot of people running true duals have removed them and I have not heard of any problems.
An actual driveshaft safety loop encircles the driveshaft so that it does not fall to the ground at speed and pole vault your car into the air or come up through the floorboard and create havoc if the Ujoints or the shaft itself fails.
You should be fine leaving it out during the time your running the dual setup.
Old Dec 16, 2005 | 10:52 PM
JoeliusZ28's Avatar
i knew it wasnt a loop, just thought it was there to catch it or something, but thanks for the info. thats probably what i will do.
Old Dec 17, 2005 | 08:11 PM
JoeliusZ28's Avatar
ok, I know LT1 tech may not have been the best place for an exhaust question, but i dont understand why its in chasis i guess i couldve worded the title better
Henson071
Sep 18, 2015 04:01 PM
Slayer
Aug 17, 2015 03:55 PM
Thirim
Jul 30, 2015 01:29 PM
Jlo
Jul 29, 2015 03:52 PM
realistyc
Jul 28, 2015 07:32 PM
