J&M Products NEW Extreme Joint Lower Control Arms
Old Dec 12, 2008 | 11:19 AM
hotpart's Avatar
Former Vendor
We are proud to release our new street/race EXTREME Joint Lower Control Arms.
1982-2002 Camaro & Firebird Street/Race Extreme Joint Lower Control Arms
The control arm bushings found in the F-Body automobiles can have a significant impact on the vehicle’s ride, comfort, handling, acceleration, noise and vibration. When the car leans (i.e., rolls) in a turn, one side of the chassis moves upward relative to the rear axle, the other side moves downward, and the control arms must twist to allow for the axle to articulate. This causes the control arm bushings to bind. If this bind becomes excessive, it will raise the rear wheel rate and produce sudden, uncontrolled, undesirable changes in handling (e.g., snap oversteer).
Chevrolet minimizes this suspension bind by using compliant rubber bushings in both lower control arms. These relatively "soft" bushings help accommodate the necessary motion of the control arms during body roll. However, the rubber bushings do not provide much in the way of forward and aft support, which can cause wheel hop during hard acceleration and braking.
It has become common practice to replace the stock rubber control arm bushings with solid or two piece polyurethane bushings to resolve the shortcomings of the soft rubber bushings. Hard polyurethane bushings eliminate wheel hop, reduce axle deflection, and improve rear straight line grip. However, the downside of common aftermarket bushings such as delrin, steel, stiffer rubber, solid or two piece polyurethane bushings is they prevent the necessary movement of the control arms during body roll, which in turn produces significant binding in the suspension when the vehicle is cornering. The polyurethane bushings also place unnecessary high stresses on the torque boxes, which are the attachment points for the control arms to the chassis. Standard aftermarket control arms do not allow for rotation of the control arm during cornering because of the stiffness of the bushings.
The Solution:
We at J&M Products designed and built a tubular lower control arm which will eliminate the unwanted uncontrolled control arm flex. Round tubing is harder to work with but has many other advantages over square or rectangular tubing. It is stronger in bending, torsion, and also lighter than square or rectangular tubing.
We then solved the shortcomings of the factory rubber and other aftermarket polyurethane and stiffer rubber bushings. This was accomplished with our new Extreme Joint. By spending countless hours looking and dissecting the geometry and the need of the rear suspension we come out with bind-free bushings set up. Our Extreme Joint bushing design incorporates a steel inner ball which is surrounded by polyurethane outer cups. This combination allows the bushing to articulate like a spherical bearing during cornering but the steel inner ball does not allow the bushing to deflect during acceleration giving you great traction during acceleration like solid bushings but remains completely bind free like a spherical bearing during cornering for great predictable traction in the corners.
* Street/Race Version uses our Bind Free Extreme Joint Bushing
* Reduces Wheel Hop & Improves Traction by Eliminating Control Arm & Bushing Flex
* Easy Installation Without Modifications
* Powder Coated Red or Black for Great Long Lasting Looks
Old Dec 12, 2008 | 03:17 PM
bluz28's Avatar
Lightbulb
Is the Extreme Joint bushings user replaceable?
What holds it in place, Snap-rings?
Old Dec 12, 2008 | 03:38 PM
Bud M's Avatar
Why no grease nipple on the other end?
Old Dec 14, 2008 | 06:00 PM
hotpart's Avatar
Former Vendor
They come with a lifetime warranty along with being replaceable. The housing is machined with a shoulder on one side and a groove for a spiral lock on the other side.
Our Patent Pending Poly-Ball bushing design does not allow for grease to flow to all the surfaces so we supply a waterproof lube that is designed for our bushings.
Old Dec 15, 2008 | 07:32 AM
Shon Herron's Avatar
Nice.
Old Dec 17, 2008 | 10:40 AM
MeanGreen97Z's Avatar
If I have purchased your lcas before can I use these bushings on the current ones?
Old Dec 17, 2008 | 12:31 PM
hotpart's Avatar
Former Vendor
Sorry but the ends are completely different between the street version and these.
Old Dec 26, 2008 | 07:13 PM
Hubes's Avatar
so are these extreme joints basically the same thing as johnny joints? http://www.currieenterprises.com/ces...nnyjoints.aspx
Old Dec 28, 2008 | 12:19 PM
hotpart's Avatar
Former Vendor
They are close to the same but with slight differences. We use a different bushing design, the outer washers on ours are made from .187" thick steel, we use spiral locks instead of c-clips, and our inner ***** are manufactured from 1144 stress proof steel to the proper size for the factory hardware.
Old Dec 28, 2008 | 01:00 PM
bluz28's Avatar
Question
Sorry, Slightly off topic.
Is the 3 piece poly-ball, or the extreme joints going to be available for your Pan hard bars?
Old Dec 29, 2008 | 11:09 AM
hotpart's Avatar
Former Vendor
The panhard rod does not need to rotate like the control arm does so there isn't a need for the 3 piece poly-ball bushings in the panhard rods.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
sseeya
Apr 9, 2015 06:38 AM
QuickSilver02
Apr 7, 2015 11:12 AM
thenewkid
Nov 27, 2014 09:41 AM
