install question
Old Sep 26, 2005 | 09:50 AM
1crazylt1's Avatar
Question install question
how do u remove/install front wheel studs?? on a 94 z
Old Sep 26, 2005 | 09:56 AM
OBE1 95Z28's Avatar
Re: install question
The proper way is to press them out and in. This insures that the wheel bearing isn't abused. A lot of guys just hammer out the old ones, then use an open end lug nut to pull the new one in place.
Old Sep 26, 2005 | 10:04 AM
1crazylt1's Avatar
wat do i have to take off beside the rim to do this
Old Sep 26, 2005 | 01:04 PM
OBE1 95Z28's Avatar
Wheel studs press into the wheel hub. The hub bolts to the spindle (4 bolts). The rotor sits on the wheel studs and the rotor is captured by the brake caliper. So again, the proper way would be to remove the wheel hub and press the studs out and in. The shortcut would be to remove your wheel, hammer out the old studs (that are now exposed) and then pull the new studs in place using an open style lug nut. Your choice.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
