Increase 0-60 take off ...better traction needed
Old Sep 30, 2007 | 02:04 PM
twind's Avatar
I have 94 camaro z28 : KN intake system, flowmaster catback, 383 stroker engine, and 400 cam I raced a WRX sti and because of his 4 wheel drive he consistenly got the jump on my ...I wanna decrease that...I heard from other suspension change could help decrease burnout ...I need to know anything possible needed to increase acceration and 0-60 takeoff....I have a auto tranny
Old Sep 30, 2007 | 02:16 PM
ttop1986's Avatar
First off get some lower control arms if you don't have them. You may want to get LCA relocation brackets as well if your getting wheel hop. Also, what tires are you running? You can have great suspension components, but if you have crappy tires, it's going to suck.
Old Sep 30, 2007 | 02:18 PM
Daniel6718's Avatar
wrong section we have one for suspen.
stall and gears...
Old Sep 30, 2007 | 03:16 PM
mrmint69's Avatar
I had bad wheel hop and installed the SLP lower control arms and the panhard bar and the poly bushings and it really helped. There are some real sticky tires for the street and slicks for the track. They wear out a lot faster but it sounds like its not a real concern now. What brand and size are you currently using?
Old Sep 30, 2007 | 03:18 PM
What is a "400 cam"?
A well-built 383, with good heads, the correct cam and a good exhaust system should smoke a WRX STI. Even if he jumps you off the line, you should blow his doors off. The more details you can provide about the engine, the better people will be able to tell you what you need to do to the suspension and drivetrain to maximize performance. Are you racing on the street or on a prepped track?
Let's move this to "Suspension........" forum.
Old Oct 4, 2007 | 12:11 AM
twind's Avatar
Thanx
Thanx guys for the info.....to be completely honest..I still am alittle unsure on what i should do first or last or @ all ...u know? But i know I have about 515 rwhp going under the hood...but I can't use it bcuz of suspension
Old Oct 4, 2007 | 07:54 PM
Soccerbum21's Avatar
i'm gonna suggest tires
made all the difference for me. on the track of course.
515 rwhp is a pretty stout car. and if you can't absolutely decimate an STi, you got something wrong. (btw, is this STi stock, bolt ons, or a hihp guy) i was hanging with my buddy's 530awhp STi at the track when i had my ET streets on. my car only makes about 400 at the motor on the bottle. we were both running 11.9s/12.0's all night. on a stock suspension.
get some nice tires before you blame the suspension
Old Oct 4, 2007 | 08:39 PM
twind's Avatar
so what else could it be
Yeah I definitely will be gettin some nice tire for tha ride I wanna go mickey t radial...but i drive my care like everyday....in the rain also...so I might have to go Nitto....so I guess I get some nice tires first then go for suspension....any suggestions
Old Oct 4, 2007 | 09:41 PM
Z-RATED94's Avatar
The MTs on a second set of wheels is the way to go, if you need traction at the track.
Old Oct 4, 2007 | 10:36 PM
twind's Avatar
Thanx to all
Ok, I think I know what to do....as far as traction...maybe now I can finally use this 515 rwhp....on the track....you know what i mean....If anyone has any other suggestions....to make the car faster...I'm open to all suggestion
Old Oct 12, 2007 | 12:34 AM
Josh'95Z28conv's Avatar
Are you guessing or have you had it on a dyno?
Im putting down close to 450 at the wheels with my setup with a stock suspension. Its really not that bad...
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jlo
Feb 3, 2015 09:41 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
