Im so ticked
Old Jun 3, 2008 | 09:07 PM
1997whitez28's Avatar
Im so ticked
I got cheap Advance auto parts whear ever brakes the silver brand and the rotors I put everything on and they squeak on turns and once and a while when im going straight. They really don't squeak when I brake. I bend the silencer and they were mint but then after 10 min there were real bad.
Should I buy better brakes or better rotors. They are new brakes and rotors in the back. I have low funds so they were the choice. I used that brake paste just to let you know.
Old Jun 4, 2008 | 08:03 AM
97FormulaWS-6's Avatar
I'm not sure, but I think those are semi-metallic pads; and because of that they will squeel at times; just the nature of semi-metallic pads. If you want to get completely rid of the squeel, get a set of ceramic pads.
Old Jun 4, 2008 | 11:05 AM
Yes they are semi metallic
They got better but when you take sharp turns you can hear them. Can you install brake pads on the wrong side? Happen to a friend and said switch your brakes from the back passenger side to the driver and vice- versa.
Old Jun 4, 2008 | 11:08 AM
Certain cars are side-sensitive, but not ours.
Old Jun 4, 2008 | 11:18 AM
thanks 97 formula for the fast response
Im gonna take my pads off and hopefully Advance auto will take them back. I will try Bendix brakes.
Old Jun 5, 2008 | 09:26 AM
I need help!!
The squeaking kinda went away but when I make slow or fast sharp turns I can hear the brakes grinding into the rotors without applying the brakes. If I take sharp turns it squeals so loud that it scares me.
When I apply the brakes in the corner they DON'T SQUEAL!!!
1slow93z28
Sep 1, 2015 06:22 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
sc93
Apr 4, 2003 02:47 PM
Chris91Z
Mar 25, 2003 02:24 PM
