i cracked both of my C5 front rotors
Old Jan 26, 2006 | 07:24 AM
  #16
CPFarhood's Avatar
Re: i cracked both of my C5 front rotors
Originally Posted by anasazi
noticed when i rotated my tires that there were little tiny cracks all the way around the rotors, in the middle where the pad hits.
well today i had to do a panic stop from like 100mph because something jumped out in front of me and when i parked at my house i checked out the rotor and sure enough there is a blue heat scorch mark about half an inch wide all the way around the center of the front driver's rotor and cracks run through it.
the passenger side is the same way although not as bad
Quit flooring the brakes at 100 and you wont have that problem.
Old Jan 26, 2006 | 08:22 AM
  #17
anasazi's Avatar
not going to happen
Old Jan 26, 2006 | 08:25 AM
  #18
CPFarhood's Avatar
not going to happen
Then i suggest you pickup some eradispeed rotors or something.
Old Jan 26, 2006 | 09:21 AM
  #19
anasazi's Avatar
hmm, for the most part blank rotors are pretty similar it seems
looks like a trip to discount is in my future for some bindix rotors. i think i'll be keeping my pads since they still seem to have life left in them.
Old Jan 26, 2006 | 10:23 AM
  #20
anasazi's Avatar
booo the thread got moved
Old Jan 26, 2006 | 10:42 AM
  #21
Ken S's Avatar
just curious, what pads are you using?
Old Jan 26, 2006 | 10:47 AM
  #22
anasazi's Avatar
GM OEM z06 pads
here is a pic, you can sort of see the cracks in the picture but in person they're clear as day
Old Jan 26, 2006 | 10:57 AM
  #23
wbna0149's Avatar
Those are just minor Heat checks. You will probably wear them off in a couple hundred miles of normal driving. Blue Hot ring nothing to worry about either . I've had them blue accross the whole rotor swept area. keep driving and enjoy them.
Old Jan 26, 2006 | 11:09 AM
  #24
anasazi's Avatar
so there isn't a chance of them opening up farther?
they are much easier to see in real life, but they don't go too deep i don't think.
Old Jan 26, 2006 | 11:47 AM
  #25
stereomandan's Avatar
Doesn't look bad at all to me.
If you are going to buy new rotors, I would just get the same ones that skull leader listed. I think those are the ones I have with my C5 conversion also, and they've worked great. It's probably what you have on there right now.
Dan
Old Jan 26, 2006 | 12:30 PM
  #26
anasazi's Avatar
alright, i'll keep these rotors a bit longer and monitor the cracks.
i got freaked out when i look at them and saw the cracks, the last thing i want is a brake failure -- especially how i drive.
thanks ya'll
RUENUF
May 25, 2016 08:10 PM
carguy0119
Apr 11, 2016 11:11 PM
RUENUF
Mar 13, 2016 03:39 PM
May 1, 2015 01:14 PM
Klypto
Mar 30, 2015 02:09 PM
