I am still having wheel hop
Old May 7, 2005 | 11:21 PM
gearslammer's Avatar
I have put on relo brackets, lca's, torque arm control, wider tires, 17" rims, adjusted the pinion angle -2deg., and am still experiencing wheel hop. Would ladder bars help, or do the lca's do the same thing? I also was told that my car is not fit for traction bars so I don't think that is an option. Please help.
Old May 20, 2005 | 12:43 AM
Re: I am still having wheel hop
With all the money I have spent I just made myself a very expensive pos. Someone help. What about a prothane tranny mount?
Old May 20, 2005 | 10:27 PM
OBE1 95Z28's Avatar
Might want to double check the pinion angle setting...common item to get wrong. The driveshaft and rear should form a "V".
Old May 21, 2005 | 02:48 AM
Eric @ DMS's Avatar
What tires are you running and where are you getting your wheel hop (at the track?)
Old May 21, 2005 | 11:26 PM
I am running F1's, and I get the hop on just about every launch, or when going from low RPM's in 2nd to WOT. As far as the pinion angle, it WAS measured at -2 deg. I am now told that that can change very easily and should be checked periodically.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
