how to put on brakes ?
i have a 1996 camaro z28 . how do i put on brake pads ? i am a complete novice . please explain in detail . i would like to surprise my husband by doing them myself. any and all help is appreciated . thanks boosmom
Sorry, I didn't mean to pick on you or make fun of you, but I don't consider you a "complete novice" if you've done those other repairs. I hope you didn't take it the wrong way.
I'm trying to dig up a site that has good instructions with pics. You can also use the Chilton or Hayes manuals, but trying to see if I can find something on line.
haha still tryin to stop laughin at your screen name
1) remove caliper
2)remove brake pads
3)use large c-clamp to press circle thingy in caliper back into caliper
4)replace brake pads
5)replace caliper
hopefully someone will find a site with pictures and good instructions
1) remove caliper
2)remove brake pads
5)replace caliper
Just a couple of tips: Leave in the old pads when your compressing the caliper so that you dont damage the piston. You usually machine the rotors with new pads, you will notice a grove in the rotors where the pad goes. If youre not doing anything to the rotors then sand the pads a bit on the edges so that they dont touch the rust on the rotors and squeek.
1) remove caliper
2)remove brake pads
5)replace caliper
1) remove caliper
2)remove brake pads
5)replace caliper
jj_burchiel
03-21-2015 12:51 AM
