How hard is it to replace the TIE ROD ENDS????
Old May 5, 2004 | 12:45 PM
SATANAZ666's Avatar
ok ive changed my shocks, springs, and upper balljoints......
I might as well do the tie rod ends.......any tips that can save me time or frustratiuon to taking these things off. I mean they look pretty straigh forwward, but i would love to hear what you guys did to take these off.
thanks in advance
Old May 5, 2004 | 01:20 PM
Bone Daddy's Avatar
Easy, just rent or buy a tie rod puller. Remove the cotter pin, nut and install the puller. Ratchet the puller down until you hear the "pop". Then you will need 2 large open end wrenches. One wrench goes on the outer tie rod nut, and the other the flat spots on the rod end. Loosen the nut, and screw the rod off.
The above is the ideal situation, sometimes the rods can be a 8itch to remove. This is when you rent/buy a picklefork. Usually you don't want to use a picklefork as it tears the boot on the rod end, but if your replacing it and the puller isn't working, it's fine.
Old May 5, 2004 | 02:40 PM
johnnyt's Avatar
tie rod end performance part?
is there a high end tie rod end. i am not too familar with this part. i noticed that the bushings on it are worn out. i was told you cant just buy the bushings for that. if i can where should i get one
thanks john
Old May 5, 2004 | 02:52 PM
Bone Daddy's Avatar
Thread Hi-Jacker!
I think your asking if they make:
A) a high(er) quality tie rod end.
-or-
B) the "grommet" or "grease cover" on the rod end that you can buy so that you do not have to replace the rod end.
Yes, and Yes.
You can buy high-end aftermarket tie rod ends, but unless your going all out, why bother? And yes, you can buy new grease covers/grommets (prothane) from suspension technologies, but for what they cost, you can buy a normally priced rod end. I have seen "tie rod rebuild kits" with the nuts,pin and cover, but they are rare, and still cost around 9$.
[edit] or are you talking about the sway bar's end links?? Your post is very confusing.
Old May 5, 2004 | 03:55 PM
Black_Z28's Avatar
Also, it's a good idea to mark a spot on the rack so you know how far to thread on the new tie rod end.
Old May 5, 2004 | 04:46 PM
Bone Daddy's Avatar
^ Yes, but if your replacing both, I'd get it re-alighned anyway. Alot of times at Sears, they have free alighnment coupons at the counter.
Old May 5, 2004 | 05:38 PM
Black_Z28's Avatar
I was going to add that, but I forgot. But it just gives you an idea where to thread it to, so you don't do too much damage to your tires.
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
teedoff59
Aug 8, 2002 01:36 AM
