How to get "Brake" light to go off??
Old Mar 1, 2005 | 06:53 PM
ToocoolZ28's Avatar
I just put rear pads and 1 new caliper on the rear of my 95 Z28. Now the brake light is on. I have a good brake pedal and bled the brakes a bunch of times.
Is there a way to get the brake light to go off?
Another guy said there may be rod sticking out of the proportioning valve that needs pushed in, but I cant find anything like that.
Ron
Old Mar 1, 2005 | 08:17 PM
NJSPEEDER24
Guest
Posts: n/a
Re: How to get "Brake" light to go off??
Ron
Check the master cylinder fluid level. There's a fluid level indicator in the reservoir. It's a magnet with a reed switch, and when the fluid reaches a certain level the magnet causes the switch to close, thus completing a ground to the brake light. Check it out, could have to do with ABS too but let me know what you find out first.
Old Mar 1, 2005 | 10:51 PM
AW/whiteZ-28's Avatar
Try holding down the brake pedal and pulling up on the E-brake a couple times, it worked for me. That light came on after I got my gears swapped.
Old Mar 2, 2005 | 08:33 AM
ToocoolZ28's Avatar
Turns out, they just needed to be bled some more.
Thanks for the ideas though.
Ron
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
