How do I adjust my panhard rod? ---
Old Mar 28, 2007 | 03:37 PM
AlwaysCode390's Avatar
Question How do I adjust my panhard rod? ---
I got it installed , but now I need to adjust it.
My axle seems to sit a 1/2 inch over to the drivers side. Do I just wrench as hard as I can on the bar with the locknuts applied? I am going to be moving the chassis over the rearend since the car is on the ground right....meaning to move the bar towards the driver side?
If I move it the way I want to .... I feel like I am going to snap the brackets that hold it on. I am sorry but for some reason I cant grasp the concept of this peice of the suspension, lol thanks---
Old Mar 28, 2007 | 04:17 PM
TobyZ28's Avatar
First thing to do (which i think you are) is to measure the distance off center it is with the suspensions loaded. Ie All 4 tires on the ground with full weight on the car. Measure using a string and nut taped to the body directly above the center of the wheel. Then measure the distance to the center on both sides.
The next part is adjusting, depends on your PHB! Is yours on car adjustable? If you have locknuts on both sides of the bar then yes you basically loosen the locknuts and using a big wrench turn the center piece. it will either move in or out, find out which direction to go by doing 1 or 2 turns and see what the change is on the sides. Adjust until the rear is centered
Old Mar 28, 2007 | 05:48 PM
Thank you VERY much....I think you answered my question perfectly...."to turn the actual bar (center peice)" to adjust it....THANKS ---
Old Mar 28, 2007 | 10:36 PM
OBE1 95Z28's Avatar
When you're done adjusting, remember to tighten down the jam nuts.
Old Mar 29, 2007 | 04:25 PM
To check the alignment side-to-side, I'd tend to use something other than the sheetmetal.... in other words don't hang the string off the fender. The fender just adds another level of build tolerance to the equation. Maybe use the distance from the subrame to the axle hub flange.
Old Mar 30, 2007 | 06:35 AM
Norm Peterson's Avatar
Aren't there some body control holes that you could work from? The crash repair industry would have to have a few known points.
Norm
Devinfoote87
Feb 12, 2016 03:21 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
mrwz28
Jul 8, 2015 09:11 PM
