Help!!! Need Camber Specs
Old Apr 9, 2007 | 01:35 PM
96badbird's Avatar
i lowered my 96 with the hotchkis springs, has anyone else used these and happen to know the new camber specs.. my brother and i are rebuilding the front end this weekend and knowing those specs would make life alot easier when we align it.
thanks guys
Old Apr 9, 2007 | 02:29 PM
http://www.f-body.org/faq/4/4_5.htm for reference.
I have been running the Hotchkis springs for many years.
Based on some info I read a long time ago, I run:
-1° camber
4.5° caster
0° toe
I don't have any excess tire wear with that camber setting.
Old Apr 9, 2007 | 04:56 PM
96badbird's Avatar
thank you thank you thank you
Old Apr 9, 2007 | 07:27 PM
Dave89IROC's Avatar
shoeboxes settings are the most negative camber I would recommend, any more might start wearing tires, caster is good, you can go slight toe in(+.20 max total toe) and not wear tires, and not negatively affect how it drives
Old Apr 10, 2007 | 08:16 AM
96badbird's Avatar
does anyone have a recomendation for the best road/track setup.. does well on the track but wont cause your tires to wear funny
Old Apr 10, 2007 | 05:18 PM
Dave89IROC's Avatar
shoeboxes settings should work pretty good
Old Apr 10, 2007 | 10:47 PM
96badbird's Avatar
awesome thanks again guys cant wait to get the new polygraphite stuff in there an see if i can tear through some corners
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
