Front tires are shifted.
Old Feb 27, 2017 | 08:02 PM
Rivas08_02's Avatar
Hey guys. My front passenger tire is pushed back about an inch and a quarter. I bought the car had it towed home. I got it started. And now.when i was gonna take it for a spin the tire is hitting the plastic behind the tire. There rubbing against each other when i turn to my left. Any suggestions. Theres no sign of it being crashed or anything i took the wheels off to inspect it and i havent been able to find anything? Help guys thanks
Old Feb 28, 2017 | 03:35 PM
Re: Front tires are shifted.
Picture? Is this with the driver side wheel straight ahead? Severe toe-out? With steering wheel centered? Does the wheel exhibit excessive camber, or is it still fairly vertical?
Some possibilities are damaged upper and/or lower control arm, seriously damaged body structure at the shock tower, damaged K-member, damaged tie-rods, bent steering knuckle, or damaged bearing in the spindle/hub/bearing cartridge.
Old Feb 28, 2017 | 03:37 PM
gaedbo's Avatar
Just curious, about how the person that towed your car hooked it up for towing. Is it possible he caused the damage by how he hooked it up and towed it.
Old Mar 1, 2017 | 08:10 PM
Rivas08_02's Avatar
That what i was thinking. He had it with the back tires up on the tow. And the front was on the ground rolling. So i was thinking when he tried to back it into my driveway he must of kind of jack knifed it l, im thinking. Im looking at the upper control arms and the one in the passneger side looks like it off of the bushing. Atleast about a good inch. I measured from my back tire to center of my front tire and im reading that its off about an inch and a quarter.
Old Mar 2, 2017 | 09:15 AM
gaedbo's Avatar
Hopefully you won't need to, but if you need a tow in the future, request the Car Carrier style truck. It's the type that they angle the truck carrier bed down and hook belts or chains to the frame and pull it onto the bed. Then they pivot it back up, secure it, and away you go. Works great !
Old Mar 3, 2017 | 11:18 PM
Rivas08_02's Avatar
Yeah. Hopefully i wont need any more towing. Tomorrow i will post pictures of the upper control arm
Old Mar 7, 2017 | 09:30 PM
Rivas08_02's Avatar
1Name:  20170304_075200_zpspwcjsxws.jpg
Old Mar 7, 2017 | 10:08 PM
Rivas08_02's Avatar
i posted picture it on the bottom of the post
Old Mar 8, 2017 | 12:16 PM
Looks a bit twisted at the top. This is the closest pic I could find of mine - I bought the car new, so I know nothing has been changed on the body. Springs and shocks are not stock. Yours almost looks like the entire panel behind the knuckle, which is part of the shock tower may have been replaced at some point in time.
Old Mar 8, 2017 | 08:33 PM
Rivas08_02's Avatar
Mines is all stock too. The shock struts are ac delco. The fuel filter was ac delco. This car , i bought i off the second owner. I compared my driver side control arm to my passenger side and its all the same! So idk whats going on. The frame isnt damaged or anything as i think. I checked all of the body inside and out before i purchased i think AAA tow truck driver tweaked something while backing in to my driveway.
Old Mar 8, 2017 | 09:43 PM
gaedbo's Avatar
If it is not measuring up when comparing drivers side to passenger side, maybe you might want to take it to a shop that can check the suspension or frame for you and see what they come up with.
Old Mar 12, 2017 | 05:57 PM
Rivas08_02's Avatar
Yeah man im just gonna take the car to get aligned and see if there able to adjust the caster. I spoke with one of my buddys so im just gonna do that. Ill let you know once i do it
