Front HUB without ABS??
Old Aug 26, 2010 | 12:32 AM
onefastmx5's Avatar
Seems like a new front hub for these cars is $160 each through autozone. I've already deleted the ABS, is there an alternate part number that will fit without the ABS for cheaper?
Thanks,
james
Old Aug 26, 2010 | 05:49 AM
Haven't seen one. Probably a slim market for that.
Old Aug 26, 2010 | 09:29 PM
onefastmx5's Avatar
man, if YOU haven't seen it before then it ain't out there. Maybe there is a way I can remove the ABS garbage and hit up a bearing shop for new bearings.
Old Aug 27, 2010 | 09:26 AM
Procharged94Lt1's Avatar
I think by the time you went thru all the effort of determining what size bearing it was and had it installed you could have just bought the 'zone one and been done.
I know it sucks but something that is important as a wheel bearing I kinda would want to know it was right. A quality bearing would probably run you more than half that anyway- plus the installation of it as well.
It sounds dumb but if you have any other Autozone's or other part stores around you call them and see what their prices are. For instance- I just checked on-line for a wheel bearing for my 94Z- on 'Zone by me has it for $182, the 'Zone 15 mins down the road has the same exact part for $223. Now go to the Advance Auto site and they have an NTP bearing assembly that has the same part number for $108- go figure.
It pays to shop around sometimes...
Old Aug 27, 2010 | 01:06 PM
n2ceptor's Avatar
Carquest around 109.00...
grabbem88
20
Dec 27, 2015 07:42 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
cyteone
Feb 7, 2015 06:04 PM
