Front end popping noise help
Old May 20, 2005 | 05:47 PM
TA2PLAY's Avatar
My 94 z28 developed a popping noise from the front drivers side on the drive home today. The car has new poly sway bar bushings, and everything else was tight. The noise goes away when the brakes are applied, but increases with vehicle speed. Should I be looking at tie rod ends or what? Car has 100k on it.
Thanks in advance.
Old May 20, 2005 | 10:25 PM
OBE1 95Z28's Avatar
Re: Front end popping noise help
Inspect the entire steering setup - upper/lower ball joints, inner/outer tie rod ends, steering coupler, rag joint.
Old May 22, 2005 | 11:40 AM
DugRat's Avatar
I chased a noise like yours for a long time, it ended up being one of the nuts on the top of the strut had worked it's way loose, I compressed the spring and tightened the nut and the noise was gone.
AdsoYo
May 2, 2018 03:21 AM
8T8IROC
Mar 26, 2015 09:02 PM
dbrockma
Feb 16, 2015 02:56 PM
Red97LT1
Aug 7, 2002 05:45 PM
