Front Driver Side Swaybar mount broken. Anyone know the part#?
Old Sep 4, 2012 | 01:42 AM
Wilson's Avatar
Looks like my front driver side swaybar bracket is broken. Anyone know where I can get a replacement?
Old Sep 4, 2012 | 07:46 AM
NJ-LE's Avatar
Re: Front Driver Side Swaybar mount broken. Anyone know the part#?
Wilson:
I just replied to your post and photo on the "intake manifold leak" thread, but just in case ...
Is that an aftermarket bracket? (Energy Suspension?) I had that happen to me. One partially split and the other broken completely. Their bushings are fine but their hardware needs upgrading. I found ES does make bushings that fit the factory (beefy) roll bar brackets. I now use those and have had no problems.
Old Sep 4, 2012 | 02:20 PM
Wilson's Avatar
NJ-LE- these were upgraded 1LE sway bars with energy suspension swaybars bushings and stock band clamps. Do they even sell beefier band clamps?
Sent from my PC36100 using Tapatalk 2
Old Sep 4, 2012 | 04:58 PM
NJ-LE's Avatar
Wilson:
Those clamps look like the ES clamps ... Mine are different. On my 95 1LE the front bar was 32mm. I assume the brackets were the same for the stock 30mm but that the bushing was bored 2mmm larger but might be wrong. I first tried the ES kit for 32mm with their brackets but had the same problem you do. For me, the solution was ES part# 3.5162R (I believe the "R" is for red) and the following is a link to those bushing that work with my original factory brackets. Energy Suspension 3-5162R - Energy Suspension Sway Bar Bushings - Overview - SummitRacing.com The stock bracket is substantially stronger and I've had no problems. I don't know what the factory number would be or if there is a difference between 30 or 32mm brackets. It's possible any 4th gen gm F-body bracket from a salvage yard would work. If you think it would help I'll take a picture of it when the rain finally stops. (they say another 3 or 4 days) I've had no problems with the rear bar but I think, after the rain, I'll take a look anyway! (I used Mobil 1 synthetic chassis lube on mine some years ago and have never had them bind or squeak)
Old Sep 4, 2012 | 05:24 PM
Wilson's Avatar
I'm pretty sure those are the stock clamps. These were on the car for over 10+yrs LOL. Seems like i found them on gmpartsdirect for $7.83 each. For that price I'm going to swap both sides on the front. Maybe it will last another 10 yrs!
Old Sep 4, 2012 | 10:29 PM
My ES sway bar bushing brackets had Zerk fittings with red plastic caps, and were gold anodized and smooth. Those look like stockers.
Old Sep 4, 2012 | 11:18 PM
Wilson's Avatar
Its been so long but I think its stock since it doesn't have that zinc color to them like the es bracket. The stock bracket will still work on the es poly bushings right?
I found these online but dam $115!
http://www.hotchkis.net/heavy_duty_b..._brackets.html
Old Sep 5, 2012 | 11:04 AM
NJ-LE's Avatar
Wilson:
I know the stock 95 1LE bracket is not hand pressed flat stock so I tried to get a shot from the garage floor. You can see the side stiffening ridges ... this is almost certainly done with a machine press. It can't be seen from this angle, but it's thicker than the ES brackets I had (they lasted me about 2000 miles). The ES are 3/32" thick. I couldn't get to measure the stockers but I know they were thicker ... at least 1/8", possibly 5/32". I don't have a way to post photos so I'm sending a copy to you and the "Injuneer". I suspect (since you said you got your brackets from gm about 10 years ago) gm was substituting the ES parts. It would take a very serious wreck to destroy the stockers (or someone doing a whole chassis rebuild and forgetting where they put them!) so they probably didn't produce many spares.
I couldn't email to either of you so I had to make an album under my name to provide the photo ... I had to resize to 640 x 480. (if you need more res, the original image is 4000 x 3000 but I'd need an address to send to)
Old Sep 7, 2012 | 04:44 PM
Stock front:
ES rear:
I had the ES stuff on the car from about 1997 to 2000 and put maybe 35,000 miles on it in that time with no problems. I'm not sure why I used the ES in the back and the GM in the front.
Old Sep 16, 2012 | 10:00 PM
Wilson's Avatar
Repaired with new stock clamp.
Wonder how the old clamp broke.
Old May 30, 2013 | 11:24 PM
Ricardo's Avatar
Wilson:
I just found out I have a broken bracket exactly like yours on the drivers side too.
I am also running an 1LE 32mm front sway bar and stock brackets. That might be the cause....
Well, I guess another stock bracket should last for an additional 10 years.
Old May 31, 2013 | 12:30 AM
Wilson's Avatar
Originally Posted by Ricardo
Wilson:
If you need the part # its in the photo. Should be a cheap fix with the GM bracket.
karnykamaro
Feb 2, 2015 01:37 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
