Front A-Arm bushing shells?
Old Mar 15, 2005 | 11:40 PM
Bow94z's Avatar
i bought prothane bushings for the front Control arm's. in my searches there i've read that there is shells that the poly bushing needs to be insterted into?
Think my stock 132K car still has them left or you think they crushed into pieces?
Upfront has alot of movement because of worn bushings
Old Mar 16, 2005 | 05:08 PM
NBred94's Avatar
Re: Front A-Arm bushing shells?
The shells are just the metal sleeves that the stock rubber bushings are attached to when the A-arm is assembled. Burn out the rubber material with a torch, and the shell will be all that is left. I wouldn't think that the sleeves themselves should ever wear out, regardless of milage.
96SilverRam
Nov 20, 2016 11:19 AM
96SilverRam
May 5, 2015 09:56 PM
8T8IROC
Mar 26, 2015 09:02 PM
Red_94Formula
Mar 7, 2015 09:21 AM
dbrockma
Feb 16, 2015 02:56 PM
