Easy way to adjust the toe? (hit curb)
Old Apr 19, 2007 | 12:29 AM
Skull Leader's Avatar
Question Easy way to adjust the toe? (hit curb)
Well, my ABS locked up because of the damn module totally dying and I smacked a curb, mooshing my rim and something else. My drivers side wheel looks like this
when the steering wheel is straight, passengers wheel is like this
Not that bad, but off alignment very noticebly. I was able to drive home like a mile, it was like running with a cracked kneecap. Close inspection showed nothing out of the ordinary, spindle looks fine, Corvette rotor spins freely. I can only guess a tie rod adjustment is the best way to get Skull-1 to a tire place to A. get tires mounted (might as well get em all) and B. get things properly checked out without flatbed towing. I have not yet had a chance to bust out the jackstands to really take a look.
Old Apr 19, 2007 | 08:13 AM
RE AND CHERYL's Avatar
Just inspect the suspension and get an alignment. You should probably replace the spindle too.
Re'
Old Apr 19, 2007 | 09:25 AM
OBE1 95Z28's Avatar
To get it to a shop, loosen the jam nut on the passenger side tie rod and rotate the tie rod until you get the wheels near parallel. You can use a long rod, board or tape measurer and measure the distance of the front tires across the width of the car to get a rough toe in measurement. Pick a feature on the tires (i.e. a tread groove) and measure the distance to that point from the back side of the front tires and then from the front side of the tires.
Old Apr 20, 2007 | 12:34 AM
Camaro_Guru16NY's Avatar
Or you could hit a curb again to try and straighten it out... lol jus kidding..
Definately check to see if anything is broken and take it to alighnment shop
Old Apr 20, 2007 | 03:50 PM
Question
Do I need a picklefork or somethin to take the tie rod off? Thanks for any advice.
Old Apr 20, 2007 | 06:19 PM
OBE1 95Z28's Avatar
You don't need to remove the tie rod to adjust it. The inner tie rod rotates as it has a ball joint on one end is threaded on the other end. The inner tie rod has a hex shaft; once the jam nut is loosened, rotate the inner tie rod to adjust the length.
Old Apr 25, 2007 | 08:32 PM
Question
Once again, I'm stumped. I can't get the damn nut to break free. Any ideas?
Old Apr 26, 2007 | 09:22 AM
OBE1 95Z28's Avatar
On one side the nut will be a reverse thread. If it's just frozen, let it soak in some PB Blaster.
Old Apr 26, 2007 | 01:24 PM
get out the torches
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
dbrockma
Feb 16, 2015 02:56 PM
kev93z28
Aug 19, 2002 12:48 AM
