driveshaft safety loop w/BMR Trak-Pak
Old 06-06-2006, 09:03 AM
bowtiepwr's Avatar
>Hey whats up?
anyway to the point...
I have the BMR Trak Pak ( http://www.bmrfabrication.com/F-bodySuspension.htm ) with their subframe connectors (boxed) and other items.
I am having trouble using my Metco DS safety loop anyone else use something else? may have to go with BMRs DS safety loop.
bowtiepwr is offline
Old 06-07-2006, 06:21 PM
Penz's Avatar
Re: driveshaft safety loop w/BMR Trak-Pak
I have a trakpak and I called BMR about it. They said that any bolt on type loop will not clear the arm. You have to buy one that will needed to be welded in. I think I am just going to try a cheap one from Summit and see if it works.
Penz is offline
Old 06-07-2006, 07:01 PM
bowtiepwr's Avatar
>thanks...
I just ordered their weld together DSL-004
93 RedBird
11-15-2015 08:24 AM
Rod Bender
25
09-16-2015 01:47 PM
tommalcolm
09-11-2015 03:39 PM
Daluchman1974
09-11-2015 06:12 AM
tdigger9899
09-07-2015 10:56 AM
Quick Reply: driveshaft safety loop w/BMR Trak-Pak
