does my adjustable bmr torque arm have anything to do with your 60ft ?
Old May 3, 2006 | 05:28 PM
red96z's Avatar
will the way it is adjusted affect your 60ft ?
Old May 4, 2006 | 08:15 AM
94Zpower's Avatar
Re: does my adjustable bmr torque arm have anything to do with your 60ft ?
it should , by changing the pinion angle you should be able to gain some traction and get rid of any unwanted vibration that you may or may not have.
I bought a BMR adjustable Torque arm but I havent installed it yet
Old May 4, 2006 | 04:31 PM
sseeya's Avatar
No. Your adjustable BMR torque arm has nothing to do with my 60ft time.
Sorry, I couldn't help myself.
Old May 4, 2006 | 05:10 PM
OBE1 95Z28's Avatar
Under hard acceleration your pinion gear wants to "climb up" the ring gear, thus changing the angle of the rear end. This can promote wheel hop, not planting your tires firmly on the ground for the best traction. This change of angle also causes increased drivetrain losses, as it increases the angle between the pinion gear and the driveshaft (U-joint angle). An adjustable torque arm allows you to preset a negative pinion angle (front of the different points slightly down) so that when the drivetrain is loaded under hard acceleration, the differential rises to the optimum angle for traction and power.
94Form
Jul 17, 2015 10:56 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
