Do I really need bigger rear sway bar?
My setup:
-Ground Control coilovers spring rate:500frt:150bck with Strano HD bilstein shocks: revalved fronts: stock back
-ST 35mm front sway bar
-Double Adjustable PHB
-BMR LCA
-3 point STB
- Welded SFC
Do I really need bigger rear sway bar (right now I have stock). My car is 100% street setup. I was wondering how much improvement rear sway bar will give me. I was thinking about 1LE 21mm or 23mm, nothing bigger than that...
Sebastian
-BMR LCA
-3 point STB
- Welded SFC
Sebastian
Re: Do I really need bigger rear sway bar?
The 21 mm bar is something that is complimented by a T2R and R compound tires. If you don't have at least the T2R and it is a street car, then I would hold off on running a bigger rear bar.
carguyshu
Jan 22, 2017 11:19 AM
