Did I mess up on rear sway bar endlink install?
I lubed the endlink bushings on an install of some urethane endlinks on my rear swaybar. Was I supposed to or not? If not, should I just take them off clean and reinstall?
Re: Did I mess up on rear sway bar endlink install?
The endlinks do not need lube. It shouldn't affect them one way or the other but I can't really speak from experience since I've always installed 'em dry.
If in doubt, just remove one, clean it, and reinstall. Then do the other one. Easy.
I actually just did mine today, went with E.S Poly's. Tightened the endlinks to 17lbs and you install em dry. I also installed new mounting bushings which I lubed and bolted up real good. Definately lube the mounting bushings if you replace em with new ones.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
