Crooked Steering wheel
Old Nov 1, 2008 | 11:59 AM
hey01's Avatar
Exclamation Crooked Steering wheel
So years ago my car got into a little crash, in which the person came up from behind me and ripped my front wheel off.
everything was fixed EXCEPT the steering wheel is no longer centered, i let it go but now it irritates the living crap outa me... the dealership aligned the car but left the steering wheel like that????? i don't get it but can an alignment shop fix that or did they leave something bent on my car at did not repair it?
Old Nov 1, 2008 | 02:14 PM
The steering wheel should have been centered as part of the alignment. All they have to do is turn the tie rod ends in opposite directions on each side to center the steering wheel, without changing the toe in. Of course that's assuming they correctly repaired the front suspension, and didn't cobble it up by using all the available adjustment to make up for the poor repairs.
Old Nov 1, 2008 | 06:36 PM
hey01's Avatar
yikes, prob did a crappy job repairing it then... Guess i'll be taking a trip to the shop to have it done right.
Old Nov 2, 2008 | 12:32 AM
Green96Z's Avatar
Take it to a shop that does alignment AND frame work. Then they can inspect the subframe and see if it is straight.
Old Jan 17, 2009 | 02:47 PM
sn8ke eatr's Avatar
if you let go of the wheel completely and the car goes strait but with the steering wheel in a turn position then all you need to do is take off the steering wheel and install it over one or two teeth so it presents itself strait up
Old Jan 17, 2009 | 04:40 PM
If the steering wheel has never been off or is still centered properly on the shaft (there is normaly a mark on the shaft to indicate center), then something else is wrong and needs to be corrected. Altering the wheel center position in relation to the center of the shaft is not the way to do it. You would end up with unequal amounts of turn from center to left or right lock.
Old Jan 17, 2009 | 10:52 PM
+1
Do it the right way.
Old Jan 21, 2009 | 10:04 AM
hey01's Avatar
I took it in and got a full alightment - drives great now.
Old Jan 21, 2009 | 10:17 AM
JakeRobb's Avatar
Super Moderator
My understanding was that it drove great before.
Is the wheel centered now too?
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
