Clunking w/ tubular lcas?
Old Aug 27, 2009 | 02:07 PM
JeffsWorld's Avatar
My car clunks in the rear when I go over even the slightest of bumps or transitions. Anyone else have this problem? I am not overly concerned and have had them installed for +10 years w/o drivability issues and am just thinking about it now, so can't be too serious, just curious if I am alone with this? They have the poly/rubber combo bushings and I know that it (the "clunk") was there before the other basic upgrades, phr, swaybar/links, springs, dd subframes. Could it be something else?
Old Aug 27, 2009 | 07:56 PM
bluz28's Avatar
Check the right rear exhaust hanger rubber isolator, it could be worn-out causing the over axle exhaust pipe to contact the PHB upper support. Or maybe your exhaust is just too close to the PHB upper support.
Also check the spare and jack, they might be loose.
Old Sep 21, 2009 | 08:27 AM
teke184's Avatar
had that happen when i didn't have the bolts torqued down enough. maybe they worked loose.
could also be a bad shock
or as stated, a mount. check the ta mount as well.
Old Sep 21, 2009 | 11:25 AM
JeffsWorld's Avatar
you wouldn't happen to know what the torque spec is?
Old Sep 21, 2009 | 03:36 PM
97FormulaWS-6's Avatar
10 years with the poly/rubber combo... right there... replace the bushings!!! I mean poly lasts, but it does wear out over time. LOL!!!
If you have rod-ends, then those normally make noise, mine have almost since day one when going over crazy bumps.
Old Sep 21, 2009 | 08:03 PM
JeffsWorld's Avatar
Looking back at it, I know the clunk started about the time of the lca install +/- 10 years ago. Would poly deteriorate even if not used to at a normal rate of use? I average about 300mi a year on the 'bird, with the first 10,000mi on the odometer coming my first year of ownership when I did not have a daily driver.
Old Sep 22, 2009 | 07:26 AM
If the clunk started when you first installed them, then it's probably a loose or not tight enough bolt.
I know poly/rubber do deteriorate over time, regardless of usage, they just do it faster with more usage. I'd say you're probably fine, just go back and torque the hell outta everything.
Old Sep 22, 2009 | 06:53 PM
Bud M's Avatar
It's been so long since I did mine that I don't remember but it was breaker bar tight, not just ratchet tight.
Old Sep 27, 2009 | 12:28 AM
greenmachinedriver's Avatar
the torque spec is PFT (pretty f***ing tight)
Old Sep 27, 2009 | 02:50 PM
Z-RATED94's Avatar
It's time to check them out. Could be as mentioned and you didn't tighten them enough or the bushings are beat up at this point. I just replaced the poly bushings at the back of the control arms with some solids. Mine were starting to push out as I have relocation brackets and there was a little to much space between the bushing and the bracket.
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
Boss002
Jul 24, 2015 10:47 AM
