Car wanders all over the road
Old Jun 3, 2007 | 09:26 PM
SS1156's Avatar
I have noticed my car wanders all over the road. The alignment is right on spec, I have checked it twice. The car darts all over the lane. The front end is tight, the ball joints and hub bearings are tight. I was told it might be the tires. I'm not sure what it is. I'm trying to wear these tires out to try some new ones.
Old Jun 3, 2007 | 10:11 PM
What size wheels and tires and what brand/model of tire? It makes a big difference on how it tracks. Wide tires with short, stiff sidewalls are going to track in ruts and uneven crowns.
Old Jun 4, 2007 | 06:19 AM
SS1156's Avatar
Sorry Shoebox, I have the stock 17x9's with 275/40zr17 Kumho 712 Ecsta's on it. I noticed that it has gotten worse. It didn't do this when I had the original Comp T/A's on it.
Old Jun 4, 2007 | 03:21 PM
2000GTP's Avatar
A damaged tire could be a possibility. I had damaged a belt in a tire before and if I took my hand off the wheel, the car would violently pull.
Old Jun 4, 2007 | 03:58 PM
ConElite's Avatar
Mine did the same when I changed my tires in the rear. I have 245/45r16 in the from and put some 255/55zr16 in the rear and OMG it was pathedic. I was having a hard to even driving at all. I thought for a second that they took my panhard and control arms off. It got better once the tires got broken in but its still loose. Im hoping when I get the matching tires up front, it will tighten up.
Old Jun 6, 2007 | 02:05 PM
popstoy's Avatar
make sure there rotated(direction)if applys the right way.
Old Jun 6, 2007 | 02:08 PM
I have had the very same tires with same size wheels and I would say tracking is worse with the Kumhos.
Old Jun 11, 2007 | 07:22 PM
STAYBG87Z's Avatar
rotate tires!
Old Jun 12, 2007 | 08:38 AM
mzgp5x's Avatar
17" by 9 wheels with 275_40 rubber (BFG KD) on the front will pull the wheel with an uneven road surface. My 97 does it all the time for all 30k miles. I do like how it handles.
Old Jun 15, 2007 | 11:25 AM
Ultra_Dog's Avatar
I have a 96 Z28/SS and with the 17" ZR1s, they dart constantly over irregular road services. There is even a caveat in the owner's manual from SLP regarding that problem.
If your tires are new, you shouldn't be experiencing that problem. However, I ride on Michelins.
Feffman
Oct 9, 2015 05:42 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
